Shower system help
chuc
SLC
Hi all,
Thanks in advance for any help here. We are doing a bathroom remodel and I feel like everyone I talk to gives me a different answer--even employees at the same plumbing supply store. I'm hoping to arrive at some sort of consensus.
Our bathroom is completely torn apart, but here is a rending of the remodel we are doing:
Obviously the valves are missing here, and that's what I'm trying to figure out. I really wanted to put the shower heads on their temperature and each group (of three) body sprayers could be on their own temperature and volume. The salesman we worked with at the plumbing store suggested we go with Moen and use five 1/2" Moentrol valves for everything. So, we'd end up with 5 Moentrol valves and handles looking like this:
Conceptually, I really like this idea, but I was worried about water pressure in this scenario. The Moen body sprayers were 2.0gpm each, but we also looked at ones that were 2.5gpm each. We had talked to another salesperson at the same store that insisted that 3/4" supplies should be run if we're using body sprayers. The salesman suggesting the 5 Moentrol valves (push/pull for volume, turn knob for temperature), however, insisted we'd have plenty of pressure and that the heads only connect to 1/2" supply lines anyway, so there was no sense in using 3/4" supply lines. I do have access to the 3/4" lines coming off the main, FYI.
Confused, I called Moen today, but since I'm not a contractor, they wouldn't let me talk to their "pros," so I had to try to relay all of this information over the phone to a lady that would put me on hold and talk to the pros and then relay their response back to me. They suggested using two 3/4" thermostatic valves for each side, with separate volume controlling diverters for the different heads. It seems like this is what most people were suggesting when we went out shopping, but it doesn't solve my desire to be able to control temperatures separately (the reason I want this, JFYI, is because the rainfall shower head, hand shower, and body sprayers will all be different distances away, and it seems like it would be really nice to tweak the temperatures separately just how you want them).
On top of all this, the people doing my remodel have just said that if the pressure isn't where I want it when they are done, they can "add a chamber of air to the water lines of the house."
I'd really appreciate any advice on how to handle this situation.
EDIT: If anyone is in the SLC and knows what they are doing, I'd be happy to pay to have this done properly. It's so hard to find plumbers right now.
FWIW, the copper institute highly suggests you don't try to move water through the pipes with hot at greater than 5fps. With a 3/4" supply line, that's 8gpm. So, add up the outputs of what you think you'll want on at the same time, and then, even 3/4" lines may not be enough. I haven't got a clue what the guy meant by adding an air chamber...I can't see that doing anything for your pressure, but I'm not sure what he meant!
You'll be mixing some cold into your line, but probably the highest capacity 3/4" valve you can find is around 15gpm, and most 1/2" valves pretty much top out at 6 gpm or so.
On a tank, you can usually get around 75-80% of the capacity before you notice the outlet cooling off. If you choose a thermostatically controlled valve, it can self-adjust the hot/cold mix to try to retain your set temperature, but it can't make hot water! A typical thermostatically controlled valve tends to be able to flow a bit more volume than a single handle one, too. You're going to need a really big water heater, and if you think about going tankless, probably more than one to get the volume you are expecting and the temperature rise. That may mean upsizing your gas line from the street and a bigger meter, too. SLC probably has hard water, so tankless maintenance would be a pain, less, if you have a water softener dialed in properly.
Rain shower heads are pretty poor if you're trying to rinse shampoo out of your hair, and maybe worse for conditioner.
For the shower construction and tiling, check out www.johnbridge.com. There are numerous ways to build a successful shower, but they are exacting...you need to know what you're doing. One study I read a long time ago said that 75-80% of tiled showers were not built to industry standards, and that can lead to an expensive mistake! It's not rocket science, but it is exacting...miss one step, and things can fail. Looking good is one thing, but it's what's underneath that keeps your house and performance up. The tile is the aesthetic, not the structural component of building a shower. You need both to be done right.
Oghemalish
San Francisco
In order to save space, shower cabins are installed in small bathrooms. They have different configurations, depending on which they are called a shower corner, a cabin or a hydrobox. The installation of the shower cabin is carried out in places where there is already a supply of pipes with hot and cold water and where it is possible to connect the drain pipe of the shower tray to the sewer pipes. If there is no such possibility, then it will be necessary to do a lot of work on the supply of hot and cold water pipes. We will have to carry out a sewer pipe. It should be noted that the diameter of the sewer pipe should be more than forty millimeters. You can find out more about this with the 2 outlet shower system.
John Gayewski
Iowa
A shower like this will only be used to its potential maybe a couple times when you first build it after that it won't get used.
