Shower Pressure
Hgainer
I live on the top floor of a high rise, with lousy water pressure. Last week I started a remodel of one of my bathrooms. I was told to switch to 3/4" shower valve and head for better performance. So I replaced the copper 1/2" lines from the 1 1/2" main lines to 3/4" leading to the shower, I found a valve with 3/4" inlets but not a shower head (other than those rain style heads). Do you know of a regular shower head with 3/4" inlet? Or any advise on improving my shower performance while I have everything apart.
shower
Do not put too much faith in an improved shower. If there is not enough water pressure up there, larger pipes will not improve it, and they probably will not supply any more volume if the smaller pipes were giving you all that was available. A 1/2" shower head and arm will give you the federally mandated maximum flow.
First thing I'd do is pick up a water pressure gage and quantify your actual pressure.
A pressure tank will not increase you pressure; all a pressure tank does is store water pressurized by the pump. It might be a help if the lines were restricted and you had a volume problem, but unless the 1-1/2" line is galvanized and all rusted out inside, it should have enough volume. For a pressure tank to do you any good, you'd need to also add a pump.
If you find the pressure to your unit is really low, you might be able to get the building owner to own up to it and put in a higher pressure pump to address the problem. You need some numbers. Then, I'd consider talking to the building inspector if it was really low.
