Shower drain clog
Dave95v6
Ontario
Hello, I’ve been having difficult time unclogging a shower drain. The shower drain shares a bathtubs drain. I’ve used plunger/draino/snake without success. I cannot get the snake to go further down the drain as it only finds a way to the tubs drain or vice versa. No matter how patiently I use the snake it will come out through the other drain. Any suggestions would be appreciated.
Sylvan
Still learning
New York
Using chemicals is USELESS and can cause major problems
When we do drain cleaning and someone uses Draino we add a $100 extra surcharge as now my employees have an added risk due to the lye which can cause burns and possible eye damage.
They now need to wear extra protection goggles, long sleeve shirts ,rubber gloves
The best way is to snake through the Shower drain as it is 2" (hopefully) and the trap should be under the drain outlet
Snaking though the tub over flow is a challenge unless you use a very flexible cable such as a Rigid K 40 machine which I am selling two of them
Dave95v6
Ontario
thank you for your input Sylvan
WorthFlorida
Solutions
Orlando, Florida
Is the tub and shower back to back? A double sanitary tee may have been used but what is not know if the drain goes down o the main from the tub or shower, I would venture to guess it's at the tub. What type of lever is used tp close the tub drain? A toe stopper at the tub drain, a trip lever with a stopper or lever to the tub drain. Just google tub drain assembly to see the three variations. If the over flow has no lever or a lever with a stopper as shown below it can be removed and snake from the overflow. However, I would think the tub would also have a problem draining.
Dave95v6
Ontario
You are right, the shower and tub are back to back, and both have draining problems. When draining water from the tub, it fills up in the shower but not vice versa. Attaching pics.
Dave95v6
Ontario
I'm able snake through the overflow pipe after removing the cover no problem, but the snake comes out at the shower drain every time and clean no debris at all.
Sylvan
Still learning
New York
The Shower is lower then the tub so of course it will have drainage filling first.
Again TRY to snake from the shower with a drop head cable or a
General Wire 120050 Flexicore Cable 1/4 inch x 25', With Double Down Head
Just go very slowly
