Steve Furbish
I have a 60+ year old ranch that sits on a full basement. I recently had a new septic system installed (last November) when the old homemade system finally failed. The new system is an elgen system with a 1200 gallon tank, divided in the middle, that empties to a small pump tank before it's sent to the Dbox and to the elgen field. About 3 weeks after the new system was installed I started noticing a septic gas smell every time my wife does the laundry. The smell fills the house upstairs and down after the first spin cycle. The drain plumbing is a 3" waste stack that runs from the upstairs toilet down through the cement floor and out to the septic tank. There is a 3" vent stack that runs from just below the upstairs toilet up though the roof. Below the vent is a 2" drain pipe from the upstairs tub and sink (vented with an AAV), a 1.5" drain from the kitchen sink and dishwasher (also vented with an AAV), a 2" drain from the washing machine standpipe (vented with an AAV) and below the cement floor a 3" cast metal drain that handles the downstairs toilet and a closed off shower drain (not vented). I have replaced the wax rings in both toilets and had a plumber in to redo the above mentioned kitchen and bathtub drains. The gas smell persists and I noticed today that the downstairs toilet bubbles up pretty hard when the upstairs toilet is flushed, but there's no gas smell unless we run the washer or take a shower. My plumber leak checked everything above the floor and could not find the problem. We check all of the traps after the washer ran and none were siphoned out. At this point I'm kinda stuck. I was unable to find anyone in my area that does smoke or peppermint testing. Anybody got any ideas for a next step?
