In the process of redoing my master bath and need to add a second water heater because of the new tub. I was going to hire it out but with the confidence I have from doing the bathroom plumbing (it all works perfectly thanks to the help I got here), don't think there is any reason I couldn't save a bunch and do the water heater as well.
House is 2.5 baths. One has a standard tub shower combo. Master has 60 gallon soaker tub and walk in shower with 2 2.5gpm heads. It's only me right now but plan to be here a while so that could change. House currently has a 50 gallon 8 year old electric heater in the attic. It's enough during the summer but during the winter I can barely fill a standard tub. If the shower or anything else has run or needs to run I'm outta luck.
1. Plan is to add a 40 or 50 gallon in series. Then replace the old 50 gallon in a few years with another 40 or 50 gallon. Any issues with that sizing plan?
2. Wondering if I would benefit from a hybrid heater. I'm located in west TN so we do get below freezing but for most of the year we are in the ideal range. But we also have some of the lowest electric rates in the country.
2. My house pressure is about 90psi with 100psi spikes when a fixture is turned on. due to uponor pex in the master reno I want to reduce the water pressure which means a PRV and expansion tank. Will the prv be as effective if installed on the cold input line in the attic near the water heater? That would be easiest for access reasons.
3. Any other considerations? Any reason I couldn't diy this having done the bath plumbing, including copper soldering?
