Scala1 booster pump help with expert settings
Roadrunner255
Austin, Texas
Looking for assistance with the expert settings and suggestions for the following.
Dry run or water shortage (stops pump after 40 sec during operation )
Default On
Auto reset action - The pump will attempt eight restarts at five-minute intervals. If not successful, this cycle will be repeated after 24 hours.
Anti-cycling alarm (leakage detection)
Default - On
Auto reset action - function will attempt to reset after 12 hours, and the pump will return to normal operation.
Maximum run time (stops pump from running eg broken pipe)
Default - Fixed disabled, only configurable via GO Remote.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
If the Scala is still in warranty have them replace it. If it is out of warranty, which is as long as those things are made to last, then you are responsible for replacing it. They are designed to be replaced often. I don't think you can do much repair on them. If you want something that will last 30 years without any maintenance, get a regular jet pump like a J10S and use a PK1A to control it.
