Salty water
Jlwalker4438
Michigan
I have a Pentair 5600stx. It has worked fine for the last few years, but lately we have been getting really salty water, like ocean water. When it first cycles it is fine, but as time goes by it becomes more and more salty. Any thoughts on what might be the issue?
What timeframe are you seeing? After a regen, water is fine for the first 20 gallons, and then gets salty for the next 200 gallons, or what? Or after a regen, water is fine for the first day, and then gets salty for the next 6 days, or what?
If the problem was that the water was salty just after a regen, and then cleared up, there would be an easy solution.
I suggest that after a regen, note the brine level. Then when the water has become salty, what has happened to that level?
To note the brine level, you may want to insert a yardstick or dowel down the brine tube as a dipstick.
Faisal
Bangladesh
A Reverse Osmosis (RO) water treatment plant is a sophisticated system designed to purify water by removing impurities, contaminants, and dissolved solids. Here's an overview of how RO water treatment plants work and their importance:
1. Filtration Process:
  • RO water treatment plants utilize a semi-permeable membrane to separate impurities and contaminants from water.
  • The process involves applying pressure to push water molecules through the membrane while blocking larger molecules such as salts, minerals, and pollutants.
2. Removal of Impurities:
  • RO systems effectively remove various contaminants, including bacteria, viruses, heavy metals, pesticides, and dissolved solids.
  • This results in purified water that meets high-quality standards for drinking, industrial processes, and other applications.
3. Multiple Stages of Purification:
  • RO water treatment plants typically consist of multiple stages of filtration, including pre-filtration to remove larger particles, sedimentation to settle suspended solids, and carbon filtration to remove organic compounds and chlorine.
  • The final stage involves passing the water through the RO membrane for thorough purification.
4. Benefits of RO Water:
  • The purified water produced by RO systems is free from harmful contaminants and impurities, making it safe and healthy for consumption.
  • RO water is also preferred for various industrial applications, including pharmaceutical manufacturing, food processing, and boiler feedwater.
5. Efficiency and Sustainability:
  • RO water treatment plants are known for their efficiency in removing contaminants while conserving water.
  • These systems can significantly reduce the need for bottled water, minimizing plastic waste and environmental impact.
6. Customization and Scalability:
  • RO water treatment plants can be customized to suit specific water quality requirements and production capacities.
  • They are scalable to accommodate varying water demands, from small residential units to large-scale industrial facilities.
7. Maintenance and Monitoring:
  • Proper maintenance and regular monitoring are essential to ensure the efficient operation of RO water treatment plants.
  • Routine cleaning, membrane replacement, and water quality testing are necessary to maintain optimal performance and prolong the lifespan of the system.
