interalian
My basement renovation is finally underway. Yay!
I want to re-route two 5" heat runs through engineered joists to eliminate the need for an ugly bulkhead in the main room.
I've done a little research and have found that cutting holes is permissable but no closer than 4' from the point load/bearing wall/beam to preserve the vertical load rating on the joist. The proposed re-routing would work within this restriction. My joists are 12" nominal with 9" web.
Can anybody confirm? Location Canada if that makes any difference.
Thanks in advance!
Thanks in advance!
