I am going to completely redo my well system. Currently I have a 3HP electric that can pull quite a bit of water out of the ground. I have a 1500 gallon storage tank. I have a goulds J10 1HP electric pump. I also have a higher end whole house pre, carbon, and post filtration system with a chlorine injector. My well house is big enough to expand inside. Here is what I'd like to do:
trench a second line from the well house to house for a sprinkler line. The sprinkler line will come off of the return line from the well tank and bypass the filtration system as it is not needed and wasteful. My question is, given the amount of draw from a sprinkler, would it be possible to use another goulds J10 or something similar that cuts on when sprinkler demand is present and cuts off when it is not so that I don't have to spend the money on another pressure tank? What's the best way to do this?
