Restrictions on Natural Gas refrigerators in MA?
Bill Fusco
Massachusetts
Are there any issues with natural gas refrigerators being installed in residences with natural gas?
I have heard that there might be code restrictions. Any help would be greatly appreciated.
Thank you
Bill
Bill Fusco
Massachusetts
Thanks for the reply Dana. I had been told that these refrigerators might only comply with propane hookups but not natural gas - not sure why that would be. Do you believe that either gas type should be fine for compliant refrigerators on this list? Thanks again.
IF the appliance is on the list, it generally lists specific models...if it specifies propane, NG probably won't apply. But, many of them can be converted from one to the other. The final arbiter is the inspector and the list. If it's on the list and it is installed properly, it should pass.
Not up on the relative efficiency of one verses say a typical compressor, but that might be a consideration, assuming power is available.
Bill Fusco
Massachusetts
Thanks for the help.
The approved list is not specific enough to LP vs NG so far as I can see - Good news is that Diamond has an NG model made ready at factory so no need for conversion, which is where the problem seems to occur. Wonder how I can nail an answer that its the NG model specifically that is approved.
Dana
In the trades
If the pre-approved Accepted Plumbing Products list doesn't make the distinction between NG & LP, from a code point of view there is none. The installation just needs to be done per the manufacturer's instructions. Calling the manufacturer would be a good place to start if you need confirmation.
Doing any type of residential plumbing in MA technically requires a plumbing license (even swapping a mixer cartridge in a shower), though it's often done and nobody cares when it's simple repairs only involving water. But for anything involving gas plumbing they take it more seriously, requiring a gasfitters license. It would be prudent to hire a licensed bonded pro. As a DIY should anything dangerous happen during or subsequent to the installation (even 10 years after you've moved out), you would potentially be on the hook.
Bill Fusco
Massachusetts
Great advice - I will call the mfr to see what the hookup is like. And I will definitely hire a pro.
thanks again.
