Replacing Tub/Shower with Shower
dean_a
Virginia
Greetings, new guy here. I am a pretty hard-core DIY'er, but smart enough to know when to ask pro advice or get a pro to do the work. Hoping you pros can set me in the right direction.
I am replacing a shower/tub combo in the kids bath with a shower only. The house is a two-story with basement, circa 1989. The kids bath is on the second (top) floor.
I have removed the old tub/shower, and opened enough of the subfloor and ceiling below to get at the drainage system. The picture is a rough sketch of the drain system. Only exception is the shower/tub line was originally 1 1/2", will be replaced with 2" for the shower.
Sinks combine to a 2", which joins the tub/shower (orig. 1 1/2", new 2"). The 2" then joins the 3", downstream from the toilet. No separate vent for the toilet.
My question is about venting. Appears the lav and tub/shower shared a vent (wet-vent?). Is this still appropriate for a shower-only unit? Toilet venting?
Thanks.
Dean in VA
dean_a
Virginia
OK, been doing some more learning... about wet vents. Would still like an experts opinion.
Seems to me that the wet vent here will be sufficient for the new shower unit.
Similar to this example.
or, this...
dean_a
Virginia
Here are some pics of what I am working with. Really, no takers out there to lend some helpful advice?
It's the middle of a workday...not everyone gets MLK day off...
I think you should add a vent for the shower. Now, you can tie into the vent from the sink in the attic and not have a separate roof penetration. The vent should be a lot closer. Code calls for it to be (I think in this situation) within 5'. the order of things is important when wet venting, but I do not know the specifics.
dean_a
Virginia
Jim, thanks for the reminder about a Federal Holiday. Lucky me, I could actually take the day off to work on this project. Don't get to do that very often.
