Basspro
This faucet is a single hole, 2 handle with drain brass unit. I found an "almost" correct replacement except the threads are standard G1/2". The old cartridge has a slightly greater TPI. I didn't want to force it and end up cross-threaded and leaking. Threads for the collar are perfect size.
The specs on what I ordered is:
Material: Brass, Ceramic
Spline Diameter: 7.6mm
Teeth on Spline: 20 Teeth
Thread size: G1/2 (1/2" 20.5mm)
Threaded Collar: With Threaded Collar
Size: 51mm x 18mm
My question is, has anyone else run into this problem and is there a place that can match my old cartridge exactly?
Size: 51mm x 18mm
