Aaron Beatty
Hi,
First time here, so please excuse my lack of knowledge. I fired up my boiler for the first time a week or so ago and shortly after noticed that the pressure relief valve was leaking a steady drip of water. I replaced the pressure relief valve, but the leak persisted. Having done some research, I am thinking the next step is to replace the expansion tank. Before doing so I was hoping I could get some clarity on doing so.
First of all when i tap the expansion tank it does not feel full. Also I tested the valve on the bottom of it and no water came out, does this mean the expansion tank is still good and possibly just needs the pressure adjusted?
The pressure gauge on the side of the boiler reads 12psi (see photo), should I assume that this means the expansion tank should be at 12psi also? Can I test this by removing the existing tank and just using my electric pump for the car tires?
Edit: I just tested the expansion tank and the pressure was about 13psi. Feels warm at the top and cold at the bottom which I assume is expected.
If the expansion tank needs to be replaced, the current one is a Watts ET-60 which I believe is 6.6 gallons, my local hardware has none of the same make, but has a 4.4 or 7.6 gallon Amtrol tank. Should I assume that the 7.6 gallon one would be more suitable?
lastly, in the last photo, I circled in yellow the two valves that are either side of the expansion tank. Are these the only two valves that I need to turn off before removing the expansion tank (In addition to turning off the boiler). I assume so but ask because there are about 10 valve handles incase they all need to be switched off.
Any help is greatly appreciated.
Thanks
Aaron
Thanks
Aaron
