MikeVila
I am installing a whirlpool with a different drain location than my previous corner tub in my manufactured home. The drain will only be about 36" away from original. Will this work. I have attached a drawing of my plan. If so when I cut into the 2" ABS will the pipe move enough laterally to slip the T in? Any transition needed from ABS to PVC. Someone had mentioned they thought you had to use a special glue?
