Howdy!
I did a Google search for information about adjusting the pressure settings for a well and this site showed up as the second result. I figured it would be best to start a new thread so I can get specific information.
My parent's have always had poor water pressure from the well. I do not think my father has ever attempted to adjust the pressure settings. When we were looking at the well yesterday he said he never knew how to change the pressure settings, and really had no interest in doing so. The pressure switch has been changed a few times over the years and he always just got a new one, installed said switch, and left it at that. I also believe the tank is fairly new.
We watched the gauge and the pump turned on at 15 and then turned off at 45. I do not know much about the system. The tank is an "H2OW-TO." If I had to guess I would say it's a 32 gallon tank. I believe the pump is rated at 3/4hp.
What's the appropriate range for a system like the one described above? 30/50?
I did not see a gauge on the tank. All I saw was a schrader valve. When I check the pressure this evening what should it read? Does it need to be within a certain range of the cut off value? Also, how should I add air to the tank if it's needed? Do I simply drain the tank and then add however much air is needed?
Any help would be greatly appreciated!
