Hi Everyone,
I have a new Kohler tub to install, as well as the drain and overflow kit from Kohler. You can see it has a slotted overflow which is a little unique, so had to get the correct kit directly from Kohler. I have 2 main questions:
1) As you can see from the pics, the bathroom currently has ABS in it. The Kohler kit is PVC. I've done some research, and the general consesus is the 2 don't mix well. I don't think I really have a choice here, so what is the best way for me to connec these items work together.
I attached some pics to help. I really appreciate the advice.
Jason
2) I have general confusion around the tub installation process, in regards to the pipes. Meaning, it seems it is recommended to install the new drain kit on the tub FIRST, then drop the tub in place. This bathroom is on 2nd floor, and I don't have access to the pipes from below. So I don't see how I would make the connections from the drain to the existing plumbing in the bathroom once the tub is installed. It would seem that I would have to install the drain kit onto the existing plumbing FIRST, then drop the tub in on top of it?Connect with a no-hub coupling
TL
Jason
The santee on your tub drain is upside down. Reverse it to the bend on the inlet flows down, not up
TL
