plumbbob
- Messages
- 27
- Reaction score
- 0
- Points
- 0
Hi - i've been noticing our (hot water) radiators have been in need of bleeding (cold at the top, hot at bottom) so I went ahead and did it yesterday. I shut off the system, turned off the fill line and bled the radiators. I started on the downstairs units and they bled air to water just fine. Then I went upstairs and only got air...loads of it. Almost every radiator on the 2nd floor bled air for about 15 seconds, but water never came. I wasn't sure what was going on, so I decided to turn everything back on and see if it would refill properly.
Now that it's back on, I feel some warmth in the radiators upstairs, but they are generally pretty cold. My wife is complaining that it's freezing in the bedrooms (it is) so I need to figure out why I can't get the upstairs to bleed properly.
Did I screw up by starting downstairs? Should I drain and then refill the whole system?
I could really use some help here. Thanks, Matt
