Bert Lee
I wanted to love these and almost do but I seem to have an issue that I am not 100% sure is right. I have double sumps in my basement, main and backup. Main has a Zoeller M63 (brand new) and the back up is a 2013 Zoeller M98. Both with fresh installs and factory recommended weep holes in the correct location. I purchased two of these to replace the cheap and failing check valves that had been there a while. They had a terrible backflow issue and would re-allow a lot of pumped water to renter the sump. I expected these to stop that problem. But it did not 100% as the linked video shows. At the end of the pumping cycle the valve does not instantly positively close as I have see in other videos. It does what you see in my case. Noisy, gurgling and annoying to be honest.
Both pumps do the same thing.
I also get this odd surging at the end of the pumping cycle sometimes, sounds like small crashing or boat wake waves that cycles the pump on and off, 5-6 times, seemingly sucking the last bits.
I welcome any comments on what the cause might be, similar experiences or remedies.
