Price Pfister 806 series Treviso, Need help identifying valve for trim replacement
Jessica512
Texas
Hi, need help identify what brand/kind this valve kit is from to get a replacement trim kit. There is no access to lower area. Year would have been 2009-2010 timeframe.
Marlinman
Jacksonville Florida
This is Price Pfister 806 series Treviso trim on OX6 rough valve. This trim is discontinued but a different replacement trim should not be difficult to find.
  • PfisterTreviso.pdf
Jessica512
Texas
Thanks! One more question I had bought this as a replacement Pfister Weller
3-Hole Roman Tub Trim RT6-5WR
But the main spout doesn’t go all the way down to the deck. It stops right at the gold ring?
From the instruction manual for the new one the water valve doesn’t look like it has that gold section with the screw? Is that something that I am suppose to remove?
Thanks again for your help!!!
Jessica512
Texas
It worked! Replacement spout fit right in! Only thing is the smooth pipe doesn’t have the bottom washer to cover the hole? Do you know if it needs something there?
Yes, The only item left for the spout attachment should be the snooth pipe.
Marlinman
It's best to keep everything stable. The 931-871 nut will fit this thread but I cannot tell if the threads are above the deck to attach.
