I'm in the middle of remodeling my house and am moving things around in the utility room to fit a new water softener, neutralizer, and larger pressure tank. I've got a question about the placement of the pressure tank...
Typically, I see pressure tanks installed in-line between the incoming pump and the rest of the house using a tank tee. That's how my current pressure tank is setup. It's right next to the feed from the pump coming through the floor. What I'd like to do is move the tank to the opposite side of the utility room, about 8 feet away from where the pump feed comes through the floor.
Here's where my question comes in. If I move the tank to the opposite side of the utility room, the main trunk for feeding the house is still on the other side of the room near where the pump feed comes in. Can I put a tee in at the pump feed and essentially have one side "dead end" to the pressure tank 8' away, and the other side of the tee feed the main trunk? I'm not sure if that configuration will cause problems such as stale water on the pressure tank side or some other problem I'm not thinking of. My other option would be to go directly from the pump feed -> 8' over to the pressure tank -> 8' back to the main trunk for the house. That's a lot of extra plumbing that I'd like to avoid if possible, but I certainly don't want to cause problems with this configuration.
Any suggestions or recommendations would be greatly appreciated.
