Pressure Switch
Mike Dillow
Nanaimo BC. Canada
I have a Square D pressure switch on 2 joined 81 Gallon pressure tanks . Is there a way to reduce the
20 PSI cut in / cut out range ? I would like it to be 10 PSI
You cannot reduce it to 10 psi with that pressure switch. The best you can do is to loosen the nut on the small spring so there is no compression of the spring. Maybe that gets you to 18 psi? Let us know.
WaterWorker WWDPC is one electronic pressure switch that can go to 10 psi deadband, and https://cyclestopvalves.com/products/electronic-pressure-switch-1 is another. I think electronic ones are more prone to failure. I think you could put an electronic and mechanical switch in series as a fail-safe.
Mike Dillow
Nanaimo BC. Canada
Thankyou. Just as I thought. I am trying to figure out in my mind , a way of using 2- square D,s alongside of each other ,
You cannot do that to achieve a 10 psi on/off differential.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
...and https://cyclestopvalves.com/products/electronic-pressure-switch-1 is another. I think electronic ones are more prone to failure. I think you could put an electronic and mechanical switch in series as a fail-safe.
I just purchased two new replacements for my very early built unit that lasted 8 years with my very bad water. It lasted longer than the Square D that it replaced so I'm not sure where you drew the conclusion they are more prone to failure.
I have since changed where I take the pressure sense from. As I have a hydro-pneumatic tank, I am now sensing the air pressure at the top of the tank rather that subject it to the horrible water. I figure it will last longer than I will but I got a spare just in case I live longer than expected.
