jmoser
1--why is there a 20 psi range with a pressure switch? Would it be a problem to adjust my pressure to a 30 psi range (ie, 30-60psi?)
2--I have a 30-50 psi switch, but it is adjustable. When I had the well service, they offered a 40-60 switch but I just kept the 30-50. What if I adjusted the switch to run 40-60 psi? Would it hurt the switch or cause any other problems?
3--I fiddled with the switch. Currently it is running 30-57psi. Previously it was running 30-50psi.
I was thinking that the pump will cycle less frequently if I adjusted the cut-off pressure higher. What kind of problems will this cause?
