traveling man
- Messages
- 9
- Reaction score
- 0
- Points
- 0
Gentlemen:
Had a new pump and motor installed 3 months ago. All was well until now. The pressure switch for the pump gave up the ghost and I replaced it. The switch is 20 on
and 40 off. Measured the tank pressure right after installing switch and it was 5. Turned on the power and the switch turned the pump on and ran for a while. Now when I turn on the hose the switch will come on for 2 seconds and shut off. Sign on the tank says tank pressure should be the same as the cut on pressure which is 20. I fiddled with the tank air and it is exactly 20. The problem still continues. Turned off power to keep from overworking the pump. I sure do need some help quickly. Anything you could do really would be appreciated.
Traveling Man
Traveling Man
