GregD
My pump had been cycling frequently and flow at the faucets had been inconsistent, so at the advice of a plumber friend, I replaced the pressure tank. Turns out that was just the the start of this DIY adventure.
After the tank was replaced, the pump started up but would only build to 20 psi. I replaced the check valve on the suction pipe which turned out to be stuck open. The pump was able to get up to 35 psi. I disassembled the pump and cleaned out the jet nozzle and removed the hard water sediments in the pump casing. Afterwards, the Pressure would reach 40 psi but no higher.
there is problem #1 - can’t get pressure to build
when the pressure is at 40 psi, I get decent flow at the outdoor hose faucet and in my shower, but my kitchen and bathroom sinks only dribble out. There was no major problem with those faucets before now so I am wondering if I might have an air lock or maybe some of the hard water sediment that got disturbed during the tank replacement may have travelled up and is clogging the pipes to the sinks.
All pipes are 1/2” pex except for the section between the pump and a manifold maybe 6 feet away which is 3/4” copper. I tried turning off all valves at the manifold so only the kitchen sink line was open, but it made no difference in flow.
There is problem #2 - not sure how to address the low flow on these lines.
shallow well. Grundfos JPF 3-a jet pump.
Any help is appreciated.
Greg
Greg
