Pressure loop
jpiazza
Hi. I've seen two diagrams on how to pipe a pressure balancing loop for three body sprays. One has the outlets all on one side of the loop with the inlet on the other side and the other has the outlets in the middle with the loop shaped like a figure 8. Is there a difference with these two designs? Also does it matter where the inlet comes into the loop? Does it have to come in pretty close to center of the loop or can it come into it from anywhere in the loop say at the top next to the first outlet. Thanks in advance.
jpiazza
So what's all the fuss over this loop? How should it be piped? The system has a shower head, a hand held and 3 body sprays.
Jimbo
San Diego, CA
Usually the manufacturer of these foo-foo systems provide recommendations about how to install. Check with the dealer where you bought this stuff for help on that, or contact the manufacturer directly. They may even have it on a website.
loop
Hydraulic pressures do not care about "loops" all they have to worry about is relative distances above the floor because that is what makes a difference and a loop does not do anything to change that. I install a tee in the middle and pipe up and down to the heads, but it is just cosmetic because any other arrangement would work just the same.
