Plumbing Plan with Greywater
Anshomereno
CA
Hi All
My wife and i are currently remodeling an old 20x30 shed into a mini gym, as part of this we'd like to add a bathroom to the area (It already has a lav). Being in California both my wife and i are keen to reuse as much water as possible for the yard/plants etc so ideally we can tie this into a greywater system rather than it going straight to the sewer.
Proposed plan attached
Basically trying to tie the showers and lav into a single drain which can be controlled with a 3 way valve, so it can either be reused in the yard as grey water (purple) or go to the sewer main.
any opinions or feedback is appreciated
Breplum
Licensed plumbing contractor
San Francisco Bay Area
To do it legally in the state, you have to follow the plumbing code that is designed to protect the health of all involved.
Anshomereno
CA
Thanks for the reply breplum, from my understanding greywater is legal in CA. However toilets, kitchen sinks and dishwashers are considered black (unusable) water hence why I've separated the toilet from the other fixtures.
Obviously there's other things to be aware of such as the chemicals etc we put down the drains etc The discharge will be marked as non potable and go to a drywell around trees covered by mulch, after being filtered. I plan on having it all inspected/permitted but ideally would like to do a majority of the labor my self to keep costs down and trying to help out reusing as much water as possible considering the current droughts :(
been following this as much as possible to ensure we do it correctly
Just need some guidance on the venting/layout and if that would actually work.
thanks again
John Gayewski
Iowa
I don't think you can tie the sewer into the grey water system. If the toilet backed up you'd have poopy greywater. Just two separated systems I think.
That bit of wet vent between the two shower drains needs to be 3 inch.
