Plumbing Main for Potable Water
GranBossito
This is for a new feed from the street to the house. What factors determine the size of the pipe? Is 2" the correct size of the copper main from the street to the house? Am I correct that the size of pipe is only related to water volume and has nothing to do with water pressure and that water pressure in the house is determined by the water pressure in the street? What can I do to insure a good amout of water pressure throughout the house? Thank you for your concern. :)
FloridaOrange
Plumbing Designer
SW Florida
I size based on GPM requirements and fpm (feet per minute) which takes care of psi.
2" is absolutely huge for a residence unless you're building a 20000 sq. ft. mansion.
Most cities will have a chart based on a fixture count or wsfu's (water supply fixture units.
What is your layout?
size
Pressure and volume are two sides of the same coin. IF the pipe is the correct size, or larger, then you will have adequate volume with little loss of pressure. IF the pipes are undersized, then there will be a specific pressure drop depending on the volume, up to the point where you reach the limit of the pipe. At that point you cannot get any more volume without increasing the pressure loss, but that increased pressure loss would also prevent any increase in volume, so you are at the maximum for that pipe. It is also the point where you would have the maximum sound level from the flowing water.
