Plumbing leaking after 8 months?
Jwhitman
California
About 8 month ago I added some plumbing to give me extra cold and hot water lines to install a garage sink. Attached are photos, The bottom stubs are for the sink and the top are for the washer. I added the extra pipe to make a damper. I installed the plumbing and had it open for two months before I closed up the wall. Looked good no leaks. Know 6 month later I see water seepage from under the drywall. My concern is there any problem with the way this is secured. Are the clamps not allowing enough movement or too much movement. If the mounting looks good, I will repair the joint that is leaking. any ideas. Is the pipe secured properly, any help would be appreciated.
Have you been having rain?
I assume you put that missing plug back in on the big vertical pipe.
