PLEASE HELP BEFORE I BLOW THIS TUB TO PIECES!!!
Cghammond77
Eastman, GA
We have this old bathtub probably around 1970’s and I cannot stand the handles or spout. I have tried to find the brand name on any and all things in the tub, absolutely nothing. I have bought so many different brands handles and had to return. Hot is on left side, middle you turn so shower will come on, and right is cold. I just want to know what I need to do to an upgrade the handles and spout. Do I need new valve and stems or what? I am losing it here with this tub! Thanks guys!
John Gayewski
Iowa
The spout should just unscrew. The handles themselves should just be replaceable, but there likley won't be a whole lot of options, once someone identifies it.
Weekend Handyman
Active Member
Nova Scotia
If you wanted to get a plumber in, they could replace the whole valve using a renovation plate. That would give you more options … but be more expensive.
I think that the second big picture has an adapter from a "universal" replacement knob set. I expect that can be removed by unscrewing one or two set screws. A new universal knob may come with a different adapter.
Marlinman
Jacksonville Florida
This is Sterling 030 series valve. There is not much options for this valve trim. The A2777 handles and the 99B2167 escutcheons are both currently available.
  • [Untitled] - 2022-05-24T053119.930.pdf
