Hey group,
So I am in the middle of my bath remodel and am having a case of 'while I'm at its'. So here is the thing. This part of the house (where the bath is) is on a slab and the water supply pipes come under this slab and up in the middle and go on up to the other two baths upstairs. So all of the pipes are in this area where I am working. I just finished redoing the drains to accommodate what we are moving around and now I am looking at the supply lines. So my questions is about the supply lines running under the slab and up through the concrete. There are six 1/2" (three pairs) of copper lines running in the sand under the slab and I have uncovered parts of them doing the drains. My question is, should I replace them while I am in here and everything is busted up? The house was built in 65 so pipes are about 54 years old and look fine. But they do run unprotected through the sand and up through the concrete in direct contact with the concrete. We live in NE Ohio if that makes any difference and these are near the center of the house so not by an outside wall. I know this would be a difficult job but I guess would it be foolish to NOT replace these? We are on well water and our water is pretty good, only need a little softening and a filter. The lines enter the ground from a wall in the basement where there is a manifold. So there is about 10 feet where the pipes are under the slab. I have read some things about copper pipes in contact with concrete and that that is not good. I am attaching a couple pictures of this area. I'm not even sure how I would go about doing this except to drill some holes in the concrete block wall and then bust up the floor and lay new lines. This is a well built house and I want to do things right and I think we will live here for a while. Anyways hope this isn't too long! thanks
