I need to run some3/4 pipe through a stud. A 7/8†spade bit cuts a hole that is just about perfect; quite snug.
I’m worried that the hole will be too small if the pipe heats up (domestic hot water) and that I will eventually have a failure.
Should I worry? Should I cut the hole larger? What’s the best way to make sure that the pipe does not rattle if it’s in a hole?
