Hi,
This is my first time trying to install PEX. I am putting a Kohler DTV system in my master bath (pic attached). Master Bath is on my second floor. Master Bath will have the following fixtures:
- 1 toilet
- 3 sinks (one in toilet room, two in main area - all with 1/2 faucets)
- 1 whirlpool (with 3/4" faucets)
- 1 steam shower (with one 6-port Thermostatic valve 3/4" hot and cold supplies, and one 1/2" pres balancing valve for hand shower)
If I plan on using a manifold system, what is my best option for setting up this bathroom - manifold in basement or on 2nd floor?
Is it best to have a single manifold in the basement below the bathroom, then use individual runs for each fixture? If so, then what size Pex would I run for the Main supply to the manifold and then from the manifold to the different fixtures - I have a mix of 3/4" and 1/2" fixtures.
What is the best way to supply the 6 port valve, it calls for a 3/4" supply. If I use a manifold in the basement, the manifolds look like they typically have a 3/4" supply line and 1/2" feeders. Would I use (2)two 1/2 feeders tied back into some type of reverse mini manifold to attach to the 6-Port Valve and the Whirlpool given they both have 3/4" fixtures?
My concern is running 3/4" pex thru floors and around turns, 1/2 seems like it will be a lot easier to work with.
I also have a desire to use a Hot water recirculator. I am considering just circulating it to the manifold, rather then the furthest fixture. Any suggestion on the type of circulator and best way to use it?
- 1 toilet
