zver11
I have a vent stack with a leak at a joint. Condensation keeps the joint wet. Location/obstructions makes it difficult to cut out section and replace joint but I can do a PVC repair coupling type patch. I can squeeze in a threaded clamp around the pipe to hold the repair in place until the glue dries. The problem is that the site is never dry.
I would rather not wait until spring for a hot day to do the patch. Is there any way to create a dry joint?
Pipe is 3" PVC just above a Tee feeding in 1.5" sink drain on top story of house. Attic above is very difficult to access given large amounts of blown in insulation and no flooring, joists not visible due to insulation.
I can access an area of pipe below the joint since I tore out damaged ceiling area. Would packing ice around pipe 2+ feet below joint work (force condensation lower in stack)? Would blowing in air from shop vac through sink drain pipe work?
