Singhsongs
Hello,
I have a Panasonic Whsiper Green Select fan the model #is FV-1115VKL2. Getting this installed has been an absolute nightmare. I replaced a fan that had a light, nightlight and fan. How hard could this be? Well my friend I’m on day 2 of trying to get the fan to work.
I have the regular light on a rocker with my vanity light, the fan has its own switch, and the nightlight has its own switch. All of these switches work properly for basic use.
I am stuck on the use of the modules for this unit! I have the timing module because I read that there is not a timer switch that would work with this thing and this particular model isn’t even on Panasonic’s switch chart!
Anyways, I do NOT want the fan to be continuous so I have the time delay set at 20 minutes. I have the CFM on this module set to because Panasonic tech support told me that by doing this the fan will run at the pick a flow default speed of 130CFM for 20 minutes after I turn the switch off. However, when I turn the switch off the fan turns off. I have tried turning the CFM to match the pick a flow.
The instructions on what to do with these red wires are a little vague. Is this saying that I need a fourth switch just for these wires. The wires are not supposed to be connected to a power supply. Do these wires go on the fan switch somehow or do I just have a dummy switch that needs to stay on forever for this module to work? Nothing seemed to mention this.
Thanks.
Thanks.
