HKC
I have a small backyard water feature with a submersible pump that is controlled by a digital outdoor timer. The electrical source is from a GFI plug at the side of the yard, about 75' away that leads to another outlet that i is not GFI protected. The timer plugs into the unprotected outlet and the pump plugs into the timer.
The problem I am having is that I've fried 2 timers at the point where the pump plugs into the timer. This connection point is in the open and I try to protect it by covering it with plastic to keep water away from the plug. It works for a while but eventually it fries.
I don't understand why the GFI does not shut down the circuit to protect the timer. Looking for explanation and also suggestions on how to protect that point where the pump plugs into the timer.
Thanks.
HKC
Thanks.
HKC
