Kg2k
I just had a new well drilled because of ongoing problems with my old well. My new well is only 35’ from my old well. I noticed that the water level in my old well dropped considerably after the new well was drilled. I am worried that the new well is just getting its water from the old well. It’s still too early to tell whether I am going to have the same issues but so far I am very worried that I just wasted a lot of money to move a problem 35’ further on my property. If I plug the old well am I in danger of losing the water in my new well?
Some of the problems with the old well were the casing was not seated into the bedrock. I had a camera dropped and you could see the void before the bedrock started. The water tested positive for total coliform as well as was extremely reddish-brown with lots of particles. At its worst I could only take a shower and flush the toilet a couple of times without changing the filter. There were many times I was changing filters every few days.
I tried to have the void sleeved off and that seemed to help things considerably for a while as far as the reddish-brown material. I did not have it re-tested during this time. The sleeve didn’t hold and water was leaking over the top and I am sure underneath as well. I eventually thought I would drill a new well instead of spending the same amount over years trying to fix the old well. The only problem now is I am very concerned that all of that stuff is just flowing 35’ further into the new well.
Does anyone have any advice? Should I have the old well plugged and take a chance of losing my water? It really seems like that old well should be plugged but the well drilling company never mentioned it during any of the discussions I have had. I am not een sure what is involved in that. Should I not be concerned yet and just run the water for a few weeks, even though the water level is obviously MUCH lower in my old well? Any advice is appreciated.
