Mike6f
Pipes are 42 years old, 1/2 copper to original multiturn shutoff with nasty built in spiral tube up to the toilet tank. It took two big wrenches, pipe wrench to hold the valve, and a long handle 7/8 plus a lot of grunting while hugging a toilet used by my son. Once the valve was off had to use a real plumbers tool to remove the ferrule and nut.
I put on a nice high quality Home Depot Brasscraft 1/4 turn shutoff, snugged it up with two long handle wrenches, but minus any grunting. Shutoff not only easily rotates, but will slide right off the old pipe. If I cut the old used portion off, pipe is green with corrosion and may be too short. House is due for a repipe, but these two toilets need to work in the mean time (weeks maybe couple months).
Pipe compound, grunts, or both?
I also considered stopping at the real plumbing supply and buying a better grade of ferrules.
Thanks
Thanks
