No water
twisty
canada
hi,
i have a well and the pump is in the well, last night there were some electric breakdown, went i wake up there was no water. i check the pressure tank and there was less than 10 psi. i tried to reset the water pump by reseting the breaker and it didnt work, someone told me that i can reset it by the franklin control box but there no lever on it.i heard that we can touch some connection in the box and it will reset the pump?? can someone help me plz
thank
JohnjH2o1
Florida
Is there a lever on the pressure switch? If so hold the lever down until the pressure builds in the tank.
John
twisty
canada
no theres is no lever but i heard that you can touch 2 connection a it make it restart
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
If there is a red button or two underneath the Franklin box you can push them hard to reset. If the box does not have red buttons to push, then it is an automatic reset and you will just have to check everything electrically.
twisty
canada
you mean check every pole in the box??could it be that something has busted because there was a numerous number of breakdown like 20 last night???could it be that the pump has reset to often that night??
