Hi everyone. I just bought a house with well water and I've never been on a well before and I have a couple of questions. My well pump is a Sta-Rite SNE-L (http://www.sta-rite.com/ResidentialProduct_sr_ws_jt_SNC.aspx) with a 30/50 switch. I had a water contractor over to see if I could increase the pressure to 40/60 and I believe he held the relay open to see how much the pump would push and it never really got much past 50...maybe 52, 53, so he said increasing the pressure was a dead end unless I wanted to drill a new well.
Would a different pump be able to pump more pressure?
If not, I was thinking about putting in a cycle stop valve and setting it to....maybe...47??? Or could I just set it to 50?
And as far as the pressure switch, would there be any benefit to changing it from 30/50 to something else, maybe 40/50 or could I lower it to 30/40 to store more water for the times where the pump does not kick on? Not sure how to think about it in the context of if I install a csv.
And as far as the current pump itself, does that tell me anything else about the well, such as - whether or not there is also some other pump buried in the well? Or is this above ground suction only? Anything else?
Thanks in advance!
Don
Thanks in advance!
Don
