New well, need to shock chlorinate
Kallisti5
Houston, TX
I purchased a properly with a newly drilled well (400ft, pump at 340ft, 8" bore) . Everything was fine at first, but after a week or so we began to get *STRONG* sulfur odors from the well water. Running the water for 20 minutes or so seems to reduce the odor.
I did a well test and came up with a positive for coliform bacteria. After some research I read that wells normally need shock chlorinated after drilling or maintenance to sanitize them and kill off harmless sulfur producing bacteria.
I've gotten little to no help from the drilling company, and the property is kind of out in the middle of nowhere. The way the well cap is designed, it looks like it's going to be difficult to gain access to the bore. Any tips? I assume I can unbolt the sanitary cap and lift it up after undoing the pvc slip joint. I've read you can use the vent pipe, but it doesn't look possible to remove it given the configuration.
Kallisti5
Houston, TX
Also, since the well is 400ft, and the pump/"water strata depth" is 340-395, I assume I need 0.5 gal bleach for ~50ft of water? (8" bore)
Smooky
North Carolina
I would use the vent hole to add the chlorine. Getting the vent out looks like it might be difficult but that is what I would do.
Kallisti5
Houston, TX
I was afraid someone was going to say that :)
If I can get the vent pipe off, a tee with a screw plug on the side at the base of it feels like a good idea, i'm not sure what code is but i'd assume as long as external contaminants can't get in it should be ok.
Kallisti5
Houston, TX
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
If unscrewing that vent pipe is too difficult, you could remove the bug screen from the end and shove flexible tubing up into it around the bend. Just put a funnel on the end of the tubing and pour slowly followed by tap water from a hose.
http://www.terrylove.com/forums/ind...izing-extra-attention-to-4-inch-casing.65845/ is my write-up.
Highlights include
  1. add both vinegar and bleach.
  2. measure the pH and chlorine levels of the recirculating water, add more if/when needed.
  3. use the flooding volume water to drive treated water below the pump and into the aquifer near the well.
Unscrewing the pressure relief looks like another possibility.
Ideally, you could make a spray probe that could insert and wash down the inside of the well including the upper part.
Craigpump
On another note......how are you going to protect your Pump Saver and control box from the elements?
Looks more like 4" PVC to me. Anyway, I'd move the control box then chlorinate through the vent hole. Run the pump until you pull the water level down to the pump (if possible), then introduce chlorine, wash down the drop pipe, wire and inside of the 4" than let the well recover. As the well recovers, the chlorine will be carried out into the structure and will attack the bacteria.
Texas Wellman
SE Texas-Coastal
Craig that is a very typical setup for SE Texas except the pump saver. The control box is weather rated but eventually will get rusty. Should still last about ten years. Not sure about the pump saver.
