DJ C
Hi all, thanks for you help in advance! And sorry i am sure this has been asked a million times but could find the answer in my searches so feel free to direct me to a related post if you'd like.
Scenerio: I am installing a new water pipe and new gas pipe (moving the propane tank from near house to 150' away near the well. I like to overkill things...to make sure i wont have to do it again...ever... so i rented an excavater and dug my trench about 4' deep. I am in northern california and we only get snow every couple years (not sure where the frost line is but its safe to say i am below it). The well is about 150' away from the house and has a relativly new tank...pump is probably 10 to 15 years old.
Question: i was planning to use pvc from well to house but was wondering at what point i should transition to copper? I am going to install new copper pipe throughout the house. I am going to sand the trench and want to make sure however it is done it will last and be zero maintanence in the future. Any suggestions or tips would be great!
Q2: I will be installing my poly propane line in the same trench...what is the suggested seperation for gas and water? How many inches of sand should surround them?
Q3: the gas pipe will be coming up in the side walk (concrete) of the house via an anodeless riser. Do i need to protect it or wrap it in anything so when i pour the new concrete around it there is no direct contact?
Q4: is 1 1/4" pvc for the water line too much overkill? I believe the existing is 1" but was thinking of going larger just to make sure there are no issues with pressure and if we ever needed to tap off of it for irrigation we would have plenty of volume.
Ok any other do's or don'ts would be greatly appreciated! It will not be inspected but i want to do it right and make it last regardless. I am putting tracer tape in the trench for both the gas and water for future identification.
Thanks again for your help!
