Jsmallberries
Replacing a 20 year old gas water heater with a new one that has a sealed combustion chamber.
1. No longer required to be up off the floor?
2. However, for ease of install it makes sense to put it on the old aluminum stand, any reason not to?
3.Can re-use the old one?(see pic)
4.I've never seen an expansion tank installed around here. There is a pressure release valve on an exterior hose bib, does that do the same thing?(see pic)
5. If you needed an expansion tank and none was installed, would any increase be released through the TPR valve on the side of the WH?
