J10S or J15S with a PK1A control kit.
No particular need to put it right there, but it would be helpful to put it at a similar elevation, or just a few feet higher. I think if the backup plan is to add storage in front of the pump, the determining factor would be where you could fit a storage tank.Knowing I have 12-15 psi where the temporary hydrant is below the house, mount the pump in line there. It’s basically in the front yard so I will have to run power out there to the pump and get some kind of pretty cover to put over it.
Without flow, the coils in the hose and all don't matter. If your hydrant gauge is at 13 psi, and your gauge lying on the slab is 5 psi, that just tells you that your slab is 18' higher than your hydrant. 1 psi = 2.3', so a difference of 8 psi = 8 * 2.3'.It would be ideal to have the pump under roof. Know this.. This past weekend I put a 100' 5/8 (i believe) garden hose on the hydrant and carried it up in the slab. The hose was much longer than it needed to be to get there so there were alot of unnecessary coils in the hose. When I screwed the gauge to it I was getting about 3-5 psi.
If the hydrant is the lowest elevation point you can reasonably tap into your water line and run electricity to, then checking at that location is sufficient. You just need to know, given the suction capacity of a jet pump, how low down (and far away) the jet pump would have to be to reliably produce the gpm you decide you need (be it 7 gpm or 10 gpm or whatever. Any irrigation?). And part of that "reliably" means knowing if the city water pressure fluctuates.What I could do if I can find the pump I need I could hook it to the hydrant and use a generator to play with different locations I guess?
That's true if "make it work" means get 5 gpm out of it. Because the frictional loss on a 1300' plastic pipe with 1.0" ID is 11 psi at 5 gpm.The more pressure that enters the pump the better. But you really only need 1-2 PSI to make it work. Put the pump where you want it and give it a try.
With only a 13/16" ID and 1300' of length, 4 gpm gives a pressure loss of 20 psi. So if you set a jet pump where the gauge reads 10 psi statically, you'll only be able to get 4 gpm out of the jet pump.
Maybe like this... or similar in black13/16” ID and 1 1/8” OD
