New A/S cartridge did not solve leaking problem.
Patriot305
North Carolina
I have an American Standard Ultra-Mix Pressure Balancing Bath and Shower Set Model 1363 Series. I changed the 066269-0070A cartridge, but still have leaking from the tube spout in the off position. I adjusted the stop, which limited the flow but did not stop the leak. Should the cartridge cause a positive shutoff and all that is needed is to replace it again or do I need to look elsewhere? Other than the shutoff leak, the unit works perfectly.
Any help would be appreciated.
Dj2
California
"Other than the shutoff leak, the unit works perfectly." LOL.
You could repeat the job again, and see if you can stop the leak, make sure you have all o rings in place.
Good luck.
JohnCT
Still learning..slowly
Northeast
After 10 years of no trouble, my Symmons shower valve started needing new washers/gaskets every year, then every month, then it leaked all the time. Symmons sent me a kit that included hot and cold seats and a tool to extract them free of charge. They also included a new spindle cartridge.
John
