Hello there.
I have been searching high and low, like Breadstick Ricky, and I could not find an answer.
The boiler is set up in a 34x34 garage with radiant heat. Unfortunately, it runs off a room temp sensor. (Someone forgot to put in a slab sensor).
Anyway.... the boiler either runs at WOT or off. I started looking through the menus, and noticed, that this was not set up. For example- it's set to finned tube baseboard. All dip switches are in the off position, which does not allow the setting of the heating temperature. The system does have an outdoor temp sensor.
I could use some help with some of the settings. Is there a parameter that delays the system to cycle, every time I open the garage door? (Anti fast cycling time).
Can someone clarify where the dip switches 1 and 2 should be on the current setup? Currently, I'm not able to change the temperature, only on DHW, which seems irrelevant.
Sorry about the messy thread. Seems like a lot of questions, all at once.
Thank you!
Thank you!
