I have a Red Lion RLSP 150. It has no trouble pushing 7 sprinkler heads at 3 GPM each. I have 4 zones with 5, 5, 6, and 7 heads. I measured the pressure at install 6 years ago at 40 psi. It draws from a depth of 10’.
So I went ahead and bought the pump the orange store had in stock. In doesn’t get great reviews and it’s not my long term choice - just something to test out this pipe. Is there anything I should caution before trying it? Will the pump burn out if the pipe doesn’t go to the well or if it’s no longer viable?
I’m not an expert but I’ll try to answer this. You can hook the suction side of the pump up to the pipe. Make sure the pipe and pump are full of water. (Primed). The output side of the pump doesn’t need to be hooked up to anything unless you simply want to direct it away from yourself etc. Turn the pump on. If it doesn’t suck water instantly, it’s not going to. That would mean either the pipe is not a well pipe OR it is a well pipe and the foot valve is shot. If that’s the case, I’m not sure how you’d replace it.
I’m back with a progress report. So I got the pump hooked up and no water. I traced that pipe back and it just t’s down further into the ground. I don’t know if I should keep digging or if it’s a safe bet that this isn’t a well. Thanks again everyone
It doesn’t tee. That wording was my mistake. It just elbows down into the ground. I may save the pump and use it as a booster for the service line. I think I was getting like 12-15 gpm at the hose bib and I’d like more so I need fewer zones.
