Need help with Brine & Slow rinse time calculation
SoftenerNewbie
SF Bay area
Runxin Up-flow regeneration valve: https://www.run-xin.com/upload/20190627/153734581337.pdf
Purolite C100E Resin: 2.5 cu-ft in 13x54 tank
According to resin datasheet, I need 0.25 - 0.5 gpm/cu-ft of Nacl/Brine injection. That means at 5 liters/min, the required brine (calculated at 8lb/cuft) will be injected in less than 7 mins (Brine and Slow Rinse in 21 mins). But according to data sheet Brine should be 20-40 mins. How come my brine time is coming up so short?
Should I get injector with even lower flow? Even at 3.5 liters/min, Brine injection will be 7-8 mins. I feel like I'm calculating something wrong?
SoftenerNewbie
SF Bay area
Would really appreciate if someone can help me with calculations, as its been a few days and I'm totally lost. I feel like I'm doing it right but numbers don't make sense.
SoftenerNewbie
SF Bay area
Finally heard back from Runxin so sharing info here, in case anyone else runs into this issue:
For each injector (depending on the tank size):
Brine injection rate = Total Flow Rate - Slow Rinse Flow Rate (Water)
So for Blue injector. Total Flow rate during Brine and Slow Rinse is 3.99 Liters/min of which 2.46 Liters/min is water, so 1.53 Liters/min is Brine being sucked into the valve. At 1.53 Liters/min my calculations make more sense now.
