Hi – I have gas boiler with 3 zone baseboard heat. One zone hasn’t worked for several years insofar as I need to keep the valve open to manual if I want to get heat to that zone – if would not open and close based on the thermostat settings. The problem is that zone would obviously get too much heat even if you just wanted one other zone to work. A friend suggested that the valve head may be bad.
I replaced with a brand-new valve head (careful to copy and match the wires exactly as they were). However, it still does not seem to be working.
I have to admit, looking at the wiring, it looks awfully ‘over complicated’. I could be wrong about the complication, maybe it just needs to be that way.
I have a PDF available here with pictures everything, hopefully enough for someone to see if it is functioning properly.
I would have drawn a diagram with colors, but I am colorblind and so I took the photos. Hopefully they are clear enough.
Picture:
https://www.dropbox.com/s/r7ww4tl1a3taonq/valves.pdf?dl=0
In the picture, the non-functioning zone is Zone 3 – Middle Level
My level: extreme novice
I did make sure new batteries are in each of the thermostats.
Much appreciated if anyone can provide guidance on how to get that zone3 to work.
In some picture you will see what looks like a blue wire next to Zone 3 not connected to anything, I think it was always that way.
Thanks
Mike
