I really need a sediment and water softener system so I need some help on picking it out. I have spent days reading info online to learn about the different systems, but just want to run this by the experts before placing orders. I was going to order from Ohio Pure Water since they seem to have pretty much anything and the prices are good so I'll reference them on the item that I found.
Source: Private Well Water. 360ft Deep with Grundfos 25GPM 3HP Pump and Well-Mate Blue Tank ~80 Gal.
House: 2 Adults + 2 Small Children, 3 Bath. Using Approx 1000 Gal Per Week and expected to go up as the kids get older.
Plumbing: 1" From Well Tank then 3/4" Around House
Tested Water Quality:
pH* pH 7.8
TDS PPM 384
Hardness (as CaCO3)** GPG 17.89
Iron (Fe) PPM < 0.05
Manganese (Mn) PPM < 0.05
Copper (Cu) PPM < 0.05
Sodium PPM 20.1
Tannin PPM 0.3
NOTE on GPM: I really hate low water pressure so I really want to keep my GPM as high as possible so some of the system that I found are sized a bit big, but I was looking for the high GPM flow rates in addition to capacity. I get approx 20GPM at the tank.
Sediment: I get a LOT of sediment coming up from the well that ranges in size from visible chunks to very, very fine sand. I do NOT want any filters where I need to change cartridges. I have that now and I don't really like doing it so I am looking for a system that does automatic backwashing.
OPW sells a ChemSorb system that looks to do the job, but for the same price ~$1000 it comes with either a 7000 or 2750 valve.
1) Should I go for the 2750 since it's more durable (brass) and I don't need the fancy electronics for sediment filtering?
2) Regarding size, I was going to get the 3.5 cu ft system that is quoted for 17 GPM. Is this ok?
3) $1000 is a lot, are there similar lower price options for automatic systems?
Water Softener: I estimate that we need a 48k Grain system, BUT that one is only stated for 12 GPM so I wanted to get the 80k Grain Capacity system to get 18 GPM flow rate. I am a bit confused on the whole ECO Mode to use less Salt which makes the 80k system act like a smaller one, but generally I think that would be ok and then it's not too big. In either case, it would probably only regenerate closer to once every 2 weeks instead of every 6-7 days.
4) Any concerns with getting the 80,000 2.5 cu ft system?
5) Is the 2750 Valve worth the extra $700 upgrade or just get the 7000SXT?
6) Do I need a Turbulator?
7) Which Resin should I get? Is the Canton High Capacity that OPW sells a good one to use? Or upgrade to SST60 resin?
So that's it. Please let me know what you think.
Thank you very much!!!
pH* pH 7.8
TDS PPM 384
Sodium PPM 20.1
Tannin PPM 0.3
