CM3939
Hello,
My Navien combi boiler was not giving hot water and the PSI on the system was showing zero. I drained the tank and replaced the water pressure sensor which fixed the issue. When I turned the water back on rebooted the system it quickly became too hot (above 200 degrees) and shut down with the 001 code. I'm able to hear a whooshing noise for a few minutes after it shuts off which sounds like it may be coming from the pump.
Any ideas here? The water inlet filter is clean and I just descaled the system a couple months ago. Seems like too much of a coincidence that this happens immediately after replacing the WPS so I hesitate to think it could be the pump or board.
Any help would be appreciated.
